Headlight Issue
Bought a 87' 944 without headlights. Got a second hand set (motor included). Installed the set and ran into two problems:
I would suggest that you look up edredas on YouTube for his harness video. The relays are powered directly from the battery or the alternator, depending on where you want to set things up.
The headlight switch itself is then used to turn on the relays and activate the lights; it's pretty well explained in that video. I'll see if I can find it and link it here for you. ETA: Cheers |
Headlight harness
Thanks for the U tube video😀
