Blown wire on rear ABS sensor cable???
Has anyone every seen a blown wire pop out of the wiring shielding on the the rear ABS wiring harness cable?
I applied the brakes hard at about 50 mph, and I heard a pop sound under the rear of the car, so we lifted it on a rack and noticed this wire burned or shorted in two, and it is popped out of the outer shielding. I cannot be certain this is the sound I heard, but i sure is suspicious. I suppose it could have been this way for a while.
Has anyone seen or heard of this happening before?
Updated info:
The harness cable has 5 wires in it and a barrel connector on each end. Two wires are for the speed sensors, two wires are for the brake pad wear indicator, and the 5th wire is a ground on each end with an external eye that bolts to the frame of the car to filter out electrical noise from the speed sensor (at least that's what I read online). Well... something happened and the darn *ground wire* shorted out and blew through the outer shell of the entire cable. (See photo in previous message)
I know it's the ground wire that blew because I checked continuity on the other 4 wires that run through the harness and they all check fine on both connectors on each end of the hardness cable.
