924/931/944/951/968 Forum
View Poll Results: V8 Swap or 2.5 16V
Do the V8 Swap
3
27.27%
Keep the 2.5 16v and Mod it
8
72.73%
Voters: 11. You may not vote on this poll
CyCloNe!ís 944 S Build Thread
Old 07-02-2019, 02:26 PM
CyCloNe!
CyCloNe!'s Avatar
Default CyCloNe!ís 944 S Build Thread
Well as many know I picked up a 944S for basically nothing. It shows 9,5XX miles on the title history and just under 10k on the Odometer. I am sure this isnít actual so donít worry Iím not that stupid...usually. This car runs well but needs a full work up mechanically and cosmetically. Below are some pics from the pick up day to today and a list of upcoming work. Current Project is a cut and buff of the old paint still in progress.
Future Projects
Exterior:
18Ē Staggard Wide Wheels
GT2 Fender Flares
951 Front Bumper
951 Head Light Covers
951 Fiberglass Vented Nose Panel
Cut 944 Fenders
Euro or Fiberglass Rear Bumper
Repaint
Interior:
CS Console Tray
CS Steering Wheel or Similar
Shift Boot
Replace Broken Trim Pieces
Seat Upholstery Black or Recaro Seats
SEM Sandstone Painted Console
SEM Standstone Painted Lower Dash
Lloyd Black Floor Mats
Jageng Cluster Rings
Jageng Aluminum **** Bezel
Jageng Piano Black Dash Kit
Stainless Sunvisor Clips
App Biz RS Style Black Carpet or Black Stock Carpet
Rear Seat Delete
Maintenance:
Currently Undecided As It May Get The V8 Swap But A Few Items Till Then
Timing Chain Pads
Timing Belt
Fuel Lines
Coolant Hoses
CyCloNe! is online now
Old 07-02-2019, 06:53 PM
CyCloNe!
CyCloNe!'s Avatar
Well made some more progress. Bought a buffer but thing was junk so this is all by hand at the moment. Looks a lot better than the starting point and really need to wash it and hit a few more spots. This was done with a terry cloth and 105 Heavy Cut Compound. Going to borrow my friends buffer for round 2 with the 205 Polish next. Also gona try the wax wheel on the double sided molding tape.
Old 07-02-2019, 07:27 PM
Jay Wellwood
Jay Wellwood's Avatar
I think the answer is directly linked to how thick your wallet padding is...
Jay Wellwood is offline
Old 07-02-2019, 07:35 PM
CyCloNe!
CyCloNe!'s Avatar
Lol thats probably true as well... I have a few swap parts currently and honestly was part of the reason i got rid of my last car. I didnít want to cut up the body for the GT2 flares and put the engine in a 951 since they are low production. I understand the better starting point with the trans, brakes and suspension but just couldnít do it for some reason, probably a unicorn would die in the galaxy if I did lol. I figure the cost will be close to the same either way. If I keep the 16v motor I will probably vems, exhaust, cams, s2 intake, pistons, rods and boost it which probably wonít be much different than the v8 swap. Just with vems, cams and s2 intake that probably puts me at the same cost. I can do the v8 for 4k currently since I already have a few parts.
Old 07-09-2019, 03:10 PM
CyCloNe!
CyCloNe!'s Avatar
Removed the upper back seat. I have a rear seat delete I made that will replace the bottom, just need to carpet it. Also took out spare tire and jack... everything adds up over time lol.
Old 07-09-2019, 03:12 PM
CyCloNe!
CyCloNe!'s Avatar
Tip of the S exhaust was breaking, got a regular NA one going on for now. Looks like only main difference is the resonator on the S catback.
Old 07-15-2019, 07:12 PM
CyCloNe!
CyCloNe!'s Avatar
Got a New/Used Front Cam Cover from Lart... I donít know what was up with mine but it was looking like it might fall apart any minute. I know my top cam housing bolt isnít in, itís missing so getting a replacement tomorrow. I worry the back housing maybe stripped... O the joys of POís!
Old 07-16-2019, 12:00 PM
CyCloNe!
CyCloNe!'s Avatar
Well found out the wires for the fan resistors were cut off... did a quick repair to make sure everything works. Iíll go back and loom it later. Also found out the car appears to have rear turbo phonies on all 4 corners. I have two questions though.
1) what temp does the low speed fan come on? Both mine cut on at 3/4 on the temp gauge (pic in next post)
2) what part is missing here in the pic? Near the driver fender.
Old 07-16-2019, 12:01 PM
CyCloNe!
CyCloNe!'s Avatar
H
This is when both fans cut on currently.
Contact Us - About Us - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
