944 running rich
944 running rich
Hey guys I do have a small crack in my header and I do have a replacement sitting on the table next to me but I am not sure this is 100% the issue. is there anything I can do or look at to see what is going on. maybe my O2 sensor is no good ? Car seems to run fine super smooth everywhere over 1k but when ideling around 800-900 it can stumble a little.
I would be skeptical that a cracked header would have any noticeable effect on mixture. There are so many potential causes for a stumble at idle. Spend some time reading previous threads. Search on stumble, idle miss, etc.
BTW are you basing your conclusion of it being rich solely on the stumble at idle or are you seeing something out the tailpipe. After it's warmed up, if you hold a paper towel or white cloth across the tailpipe airstream, are you getting black soot?
It might be a good idea to mention the year/model of your car, because what I'm getting ready to say may or may not apply.
I learned from reading Clarks-Garage that the fuel pressure regulator, at idle, reduces the fuel pressure. This in effect reduces the fuel dose per injector cycle and leans out the mixture. Don't quote me exactly on the numbers but I believe it takes full system pressure (44 psi?) and reduces it down to 36-38 psi at idle. It does this based on a vacuum signal just downstream of the throttle. This is the small vacuum line that goes to a Y connection that leads to the fuel pressure regulator and the fuel pressure damper. If this vacuum signal is "corrupted" then the fuel pressure will remain high and the idle will be rich.
2 things to check- Get a vacuum gauge, tee into the line I described, and confirm you have decent (> -15 inches) of vacuum in the line with throttle closed at idle. Even better is to get a fuel gauge that mounts on the end of the fuel rail and observe the fuel pressure reduces per spec at idle.
In that case, the above info is applicable.
How old are the plugs, wires, and cap? Does the car still have the original catalytic converter? How is the air filter? Just some basics before trying to diagnose something that may not be there.
cap and rotor are brand new wires and plugs are not I currently have a hot air intake I need the brackets to install the stock air box. I am sure the cat original and I would think if the ground was unclean there would be a whole host of other issues.
Good luck.
