Not Another Transmission Oil Thread...
I hate to beat a dead horse but I've spent hours searching and reading about which manual transmission oil to use. My only conclusion is there is a lot of contradicting advice out there. The question is simple: what lube goes in 951 UY transaxle? Open diff, no cooler.
I'm still not clear on GL4/GL5 ratings. My manual says 80W GL4. Apparently a Porsche bulletin says GL5?
So what do the experts suggest? My current short list is as follows:
Locally available:
Motul Motylgear 75W90 - "GL4 and GL5" - My current first choice
Royal Purple Max Gear 75W90 - "GL5 or GL4" - More expensive then Motul
Amsoil - Whatever is suggested. See my experience below.
Other options I can buy online and import into Canada (which seems ridiculous):
Mobil 1 75W90 LS
Redline MT90 or 75W90? - Most expensive/complicated option to buy. I've seen many contracting opinions around MT90.
Anyone following my restoration thread knows I previously used "Amsoil 75W90 Long Life Synthetic Gear Lube" (API GL-5 & MT-1) with devastating results after only 50 miles. I can't definitively point a finger at this lube but my replacement transaxle is on order and I don't want a repeat experience. Advice would be greatly appreciated.
Locally available:
Mobil 1 75W90 LS
Am definitely NOT an expert, but it seems all have had great experiences with everyone of those oils mentioned, except I know nothing of the Amsoil product.
Personally, I have used the SWEPCO 201 in my cars for both track events and street use and have never had any issues. They have Limited Slip ( except one ) and the cool thing is, one does not need a 'friction modifer' additive in that product for LSD. It is a superior lubricant but quite expensive.
You are going to get quite a few diverging comments, so now that the Pandora's Box is open .......
Strange coincidence about the Amsoil gear oil ... i have two cases of their Dominator 15w50 oil that i plan to use in my race engine this season !
Yikes ...
As for the transmission oil , my cars like the Mobil 75w90 which i buy in 20 liter pails for both the race car and my 911
Yikes ...
Yikes ... As for the transmission oil , my cars like the Mobil 75w90 which i buy in 20 liter pails for both the race car and my 911
Buying Motul or Royal Purple would be so much easier but I took the easy route last time and now will never know if it caused me problems. The car had sat 10 years when I bought it with no history. I drained clear (old) fluid from the transmission, refilled it with the Amsoil stuff, took it for a couple test drives and then a grinding noise began from the rear end. Ruled out CVs, so drained the fluid to this result:
I've since found an issue with the parking brake that probably added to the noise when the car was in motion, but I couldn't ignore the oil. I took the transaxle apart and was advised it needed a full rebuild. My car isn't worth that kind of money so it's getting a used UY from Lart. Again I can't say for sure it was the oil but I want to be sure I use the right stuff moving forward.
Former Vendor
Hello,
Just posted this in another gear oil thread in regards to the Mobil Delvac (a different product than the M1 gear oil) but highly regarded here. Here is some insight on the Gear 300 product:
I, of course will want to push you towards the Gear 300 75W90. It has some major upside vs the Delvac product. Starting off with the just the viscosity index, it is very low at 140 vs Gear 300 at 222- this is an oil's ability to remain in grade/viscosity as temps increase/decrease. Higher the number, the better. The Gear 300 has nearly the highest, if not the highest in viscosity index of any gear oil available in the passenger car market.
From a formulation view, the Gear 300 is also an ester based gear oil. In short, the oil film is virtually unbreakable- it is a 0% shear product (oil viscosity loss). Gear 300 remains in grade after the KRL 20 hour shear test- a very tough standard that is not regularly used by oil mfr's due to the severity of the test. We're proud of that.
Should you have any questions, just let me know. -Nick
This product is for open diff's and is a GL-4 and GL-5 product so it passes test for extreme pressure without corroding the soft metals in your gearbox. Hope that helps. -Nick
The Mobil Delvac oil is readily available in Canada , you don't have to import it ...
Last time i paid $180.00 for a 20 liter pail, as of last year the price was still around that figure !
Don't get mistaken with the Mobil oil they sell at CDN Tire, not the same thing
I'll have to inquire if Gear 300 is available but I know I can get the Motylgear if they are comparable. For the record this is a street-only application, non limited slip differential.
https://mobiloil.com/en/gear-lubrica...c-gear-lube-ls
Former Vendor
[QUOTE=Alex89;15748808]Hi Nick, thanks for the detailed information. How does the Motul Gear 300 compare with Motylgear 75W80?
The Gear 300 is our 100% synthetic ester based flagship gear oil with indusrry leading specs and performance. The Motylgear 75W80 is part of our entry level synthetic gear oil line; still very much a high quality product with high performance levels. It is also GL-4 and GL-5 approved so you're good to go there as well.
If you're in the GTA, Spec Lube carries the full line and has a retail front store. -Nick
Any Canadian Mobil/EXXON supplier carries the product , i believe you can also get it in 3.78 liter jugs ...
With the two cars and the race car getting two oil changes per season it's worthwhile for me to buy a larger quantity !
Go on the website and search in the Heavy Duty products section , then select rear axle, it will give you some options.
All I can weigh in on is Redline MT90 75W90. I've ran it in my '84 944 and currently run it in my '80 931. It improved shift quality and my driving experience in both cars. Can't say whether or not it's better/worse than the rest; only that it's a good option.
I've used CASTROL SYNTRAX UNIVERSAL PLUS 75W-90 Synthetic for 100k Miles in my daily driver 86NA since 2007
Specifically for transaxle tranny.
Perfect shifting hot or cold.
In the rest of my cars I just change it. I put redline in my car several years ago. I think it still had the original. It made a difference in my worn sincros. I recommend it.
In your situation limited options I would go with royal purple. If it doesnt help try to get something else.
When I last changed my gear oil, I used the here-in-Ontario readily available Liqui-Moly 75W-90. LM is supposed to be quality German stuff, though I have to say the one-two shift after cold start still grinds sometimes and generally no improvement over what I had before (unknown as a shop changed it about eight years ago).
Next time, I will be trying the Motul. Nick's pretty convincing
I’m using Millers Oils gear and engine oil. I’m based in Toronto and there is a local dealer. Most of the 944 Cup race cars are running it in PCA, they are also a sponsor in PCA club racing. The highlight of product is it has Nanotechnology in it. Micro ceramic nanoparticules.
Since you're in Ontario, you can always give Millers Oil a try , Bill Comat would be your guy and there is some sort of PCA or racer discount that
he can pass on to you.If i didn't have a prefered customer account with Amsoil i probably would have given his engine oil a try !
