964 and 944 Turbo/968 brakes interchangeable?
Apparently 964RS and 968 M030 rear rotors are the same part from the factory.
My question is this. Will anything that will bolt up to a 964 also bolt up to a non M030 944 Turbo/968? I can't find anything saying it will but it seems like it all will bolt right up. |
Dammit....now the 911 guys want our brakes.
Is nothing sacred?!?! ;) |
Originally Posted by Jay Wellwood
(Post 15688122)
Is nothing sacred?!?! ;) :D T |
(Post 15688122)
I thought the brakes in the 968 M030 package were the same as the 928 S4 which were also used on the 944 Turbo S and S2 with M030. |
I have the same understanding.
Porsche 928 GTS front calipers are the next size up in this family. I don't know how the 993 calipers stack up. IIRC, the 993 front and rear calipers are the same size. |
Rotors are the same, according to PET. That said, a 964 RS is pretty rare - rarer than a 968 M030.
According to PET, rear 968 calipers are 28/30 mm pistons. The 964 RS/Turbo rear calipers are 30/34. Some 964 front calipers are 36/44 - they are probably the same body as the M030 caliper (but I don't know for sure). That said, they are leading calipers so the crossover pipe and bleeders are reversed from a 968 application.
Originally Posted by James G.
(Post 15691266)
Nobody seems to make a really big "big brake kit" for the 968.
(Post 15691266)
But if the parts from a 964 bolt up it's solved.
Originally Posted by FrenchToast
(Post 15692095)
According to PET, rear 968 calipers are 28/30 mm pistons. The 964 RS/Turbo rear calipers are 30/34. Some 964 front calipers are 36/44 - they are probably the same body as the M030 caliper (but I don't know for sure). That said, they are leading calipers so the crossover pipe and bleeders are reversed from a 968 application. The only bolt-on upgrade is the 993 TT calipers on an M030 spindle. Still not a great upgrade by today's standards. Nothing from a normal production 964 is an upgrade over the 968 M030 brakes. The Leichtbau, S, and RSR models probably have bigger brakes. |
I think I have this solved. I hope I do because it's about to be ordered. If it works I'll end up with 380x32 front rotors with 8 piston calipers and 356x28 rear rotors with 6 piston calipers. If it goes to plan it all fits under an 18" wheel.
Good luck and keep us updated James!
(Post 15700940)
FWIW, the 991 GT3 runs a 380mm rotor and six-piston Brembo street caliper. It is a close fit, and that is with a 19" wheel. |
(Post 15701361)
Have you measured everything? Unless the caliper is a low-profile motorsport caliper, it likely won't fit with a 380mm rotor inside 18" wheel. It's possible but not likely.
I was remembering the Cup setup being tighter. It isn't too extreme, but is close.
https://www.autoguide.com/gallery/d/...GT3-Cup-12.jpg That's a 380mm rotor and PFC six-piston low profile caliper, with an 18" BBS high-clearance wheel. You'll just have to watch the wheel weights and leave room for wheel flex (wheels flex under cornering). I've heard of some extreme fitments that are fine static, but rub under cornering. Curious what calipers you're looking at. |
(Post 15702040)
https://www.autoguide.com/gallery/d/...GT3-Cup-12.jpg That's a 380mm rotor and PFC six-piston low profile caliper, with an 18" BBS high-clearance wheel. You'll just have to watch the wheel weights and leave room for wheel flex (wheels flex under cornering). I've heard of some extreme fitments that are fine static, but rub under cornering. Curious what calipers you're looking at. https://cimg4.ibsrv.net/gimg/rennlis...e1a15434b2.jpg https://cimg0.ibsrv.net/gimg/rennlis...a77356e697.jpg https://cimg7.ibsrv.net/gimg/rennlis...8cab9e0c0b.jpg https://cimg1.ibsrv.net/gimg/rennlis...b5dbcc2d79.jpg |
