Could someone elaborate on the rear caliper options since there are "many". How many are there for use with stock/m030 rear rotors?
I'll try to dig some stuff up. I know I've come across several different setups, but didn't save any info on it as I'm planning to leave the rears basically stock (for now anyway). We'll see if I need to change them for better balance, but I know a lot of the Big Red guys leave the rears stock and just change the bias valve. Pretty sure some options require ebrake modification especially if going with a different size rotor.
Here's one option by 9Products (the guys I bought my adapters from):
Cool project. At what point will increasing the brake piston area over stock cause a mushy brake pedal due to the increase in brake fluid volume being displaced with each pedal stroke?
Thanks. I'll let you know if what I'm doing is enough lol!
But the thread I referenced has several guys going this route and even looking at running a full 997 setup (sounds like it might have an even slightly larger rotor?). Going to dig through it some more but I haven't seen anything yet about changing out the MC or running a dual setup as T&T Racing suggests. We'll find out though.
