No trip odometer reset switch
7th Gear
i apologize, I know this was partially addressed somewhere in this forum, however since I joined I can’t find the discussion. I removed my dash trim piece to align my trip odometer microswitch, imagine my surprise, there was not one. Looked like there had never been one. Does not seem right. Cannot find a listing (pn) for the switch, where to from here?
Are you speaking of the reset ?
The series two car resets which are located in the middle of the false vent to the right ?
7th Gear
Having difficulty with site. Yes it is the reset I am referring to.
PET is the Porsche Parts Explorer. https://www.porsche.com/usa/accessoriesandservices/classic/genuineparts/originalpartscatalogue/
It's a must have if you own a Porsche and plan on tinkering with it.
7th Gear
Bought the switch, however the wiring from the instrument cluster to the switch is nowhere to be found. This is crazy, no remnants, no cutoff wires, no connectors laying inside the cluster, nothing! Any thoughts?
Did you figure this out? Currently in the same situation, bought a switch and everything, but no wiring to be found.
Here's the wiring diagram, which would make me think it plugged directly into the B plug of the cluster, but that plug has the brown/yellow pin still in it -
https://i.imgur.com/k9vgVJ3.png
I was thinking I could unwrap the loom tape and follow the wire to where it should have a connector, but that seems pretty brute-force.
https://i.imgur.com/YbUEcvo.png
Awesome paper version of the catalog is from a fellow Rennlist user.
Here's the catalog in paper. I got this from a Rennlister (thanks!) and I use it all the time.
https://www.ebay.com/itm/Porsche-944...0/152381872536
and the connector housing (944.612.547.00), which can be found here -
https://www.pelicanparts.com/More_In...612-547-00-OEM
I'm just trying to figure out where to hook them up!
