Turbo brake issues
Old 01-07-2019, 02:22 PM
Jfrahm
Jfrahm's Avatar
Wedging the brake pedal down for a while helps, makes the bubbles really small and easy to dislodge. You can use scrap wood between the seat frame and the brake pedal. Wedge the pedal down, wait 30 min or so, bleed one corner (or I suppose one inner) then lift the pedal, wedge it down again, wait, repeat on the outer, and continue around. I am not sure if waiting helps, on bikes I always let them sit a while with the brake pressure on as I had been instructed.
You want the pressure up way higher than the Motive can safely apply to get the bubbles mashed down small and a strong jet of fluid to come out under high pressure, hopefully carrying the bubble out or to somewhere where it can get flushed out more easily.
Old 01-07-2019, 02:53 PM
mj951
mj951's Avatar
Good tip.
One warning with the Motive Bleeder, if you've owned it for a few years do yourself a favor and replace the plastic tubing.
Brake fluid degrades the plastic and it will eventually fail or split creating quite the mess.
Old 01-07-2019, 03:45 PM
Otto Mechanic
Otto Mechanic's Avatar
Originally Posted by GPA951s
Buck "the system" I just put some dye in mine anyhow.. much easier to change fluid..
1. open bleeder
2. pick up beer and drink
3. Put beer down when color changes close bleeder
4 Repeat 7 more times
Ya know, there's a post somewhere here from a guy that knew exactly which dye to use to get ATE blue, If you search under my "handle" along with "brake fluid" you should find it.
I'm going to print your procedure and hang it on the wall of my shop! .
Old 01-07-2019, 03:50 PM
Otto Mechanic
Originally Posted by mytrplseven
Yeah, I know. We're the DOT.....were here to help.
Why is it these people who're "helping" never seem to be around while I'm bleeding my hydraulics?
Old 01-07-2019, 03:58 PM
Otto Mechanic
Originally Posted by mj951
Don't forget to bleed the clutch.
Truer words have rarely been spoken.
Old 01-07-2019, 05:12 PM
mj951
mj951's Avatar
Ha, it's easy to be lazy.
Old 01-07-2019, 05:27 PM
Otto Mechanic
I Sort of had the same problem with My Turbo-S … I used to have to STAND on the pedal, and that is not a comfortable feeling at Watkins Glen, and It really will mess with any heel-toe Downshifting..
I can imagine. I lost my brakes in the 928 S3 driving it back to back with my son at Laguna Seca; two different run groups but not spaced far apart enough to cool anything down, that's when we melted the pads.
I often call it "a religious experience".
Old 01-07-2019, 05:51 PM
mytrplseven
mytrplseven's Avatar
I Sort of had the same problem with My Turbo-S … I used to have to STAND on the pedal, and that is not a comfortable feeling at Watkins Glen, and It really will mess with any heel-toe Downshifting.. Anyhow, I ended up getting a Caliper rebuild Kit, I did all 4 calipers.... 16 pistons.. Took my time and was very detailed in the cleaning all new o-rings, got 30 years of junk and varnish out of the calipers. Put it all back together... Took it for a rip on the street and was a TOTALLY different car at the track.. It was amazing the difference the rebuild made... they work awesome now.
Look on YouTube, Van has a great Video on how to rebuild/clean them...I got my rebuild kit from Racers Edge. I took my time and it was about an 8 hour job. FYI You Don't need the scraper rings.. just the seals..
I've been wondering about rebuilding the calipers. I believe they've been redone by someone professional like Rennlist because the red paint quality is perfect. That being said, this was a barn find and there's no telling how long the car sat before I rescued it. I know the front pads are dragging when I turn the wheels and that doesn't seem kosher to me. By the way, I love how good your car looks. Here's what I've been building:
Old 01-07-2019, 05:57 PM
Otto Mechanic
What a beautiful car! Well done sir! Now I have one more great looking Martini car to worry about. Sigh... .
Old 01-07-2019, 06:00 PM
mytrplseven
Originally Posted by T&T Racing
DOT4 for autox is a good choice. if you mean higher stuff as synthetic or silicone, DO NOT use. These brake fluids entrap air bubbles when vibrated and the air bubbles do not escape back to the reservoir
I was referring to ATE 200 (supposedly higher temp capability) vs some generic DOT 4.
Old 01-07-2019, 06:14 PM
mytrplseven
Good tip.
I was using 15 psi and starting with the OUTSIDE of the caliper first. Is that a problem?
Old 01-07-2019, 06:21 PM
mytrplseven
I wasn't able to find your post about the blue dye. would you mind sending me the info?
Old 01-07-2019, 07:50 PM
Otto Mechanic
I have to apologize, I can't find it either. I thought it was here, I was complaining about it maybe 2 or 3 years ago when ATE stopped shipping blue fluid. A fellow chimed in and sent pictures of the dye they use. I haven't bought it so I don't have receipts. I just figured it was there and it would be there when I needed it.
Guess I was wrong. Sorry,
Old 01-07-2019, 09:46 PM
mj951
mj951's Avatar
I've always kept the pressure at 10 psi and is what most around here recommend.
The plastic tubing cracks from years of exposure to brake fluid not necessarily from psi exceeding 10.
I bleed the inside bleeder first to limit pushing dirty brake fluid through the caliper.
But doubt it matters, as long as they're both flowing clean, air free fluid.
Old 01-07-2019, 10:38 PM
Otto Mechanic
OK. Found it on a different site:
https://www.miataturbo.net/suspensio...er-blue-97675/
It's a video, the dye comes from McMaster Carr. You will have to put up with the video blogger expressing his justifiably irritated attitude. I was particularly enamored of "F**** the NTHSA". It defies logic and common sense we actually pay for and put up with this unsanity.
Quick Reply: Turbo brake issues
