944.1 NA Starts will not Run!
Glad you got it fixed! I presume you swapped one in? Or did you have your ps repaired? I'm curious if it was parts in the DME goone bad or connections (solder joints)... not sure if you know that
PS., how did you get to write "solved" in that space? I can't figure out how to write up there
Now you have some spare parts 😆 it's always a good feeling to fix something that has you stumped. Take note of how it ran before you fixed it so you'll have a reference for future troubles.
Glad your DME find is a good one!
As for the title editing, I see that you edited it from the first post... which is great... the extra "Solved" title for post #15 is baffling me; I didn't think you can add another title to a random post in a thread (ie. not post #1). In any case, I wonder how can we edit the original title--the main one that shows up in the thread listing? That would be a great place to add "Solved"!
