Brake compatibility question. 968 non M030 vs 90-94 911
For 968 non M030 hubs, anything that will bolt on to a 90-94 911 Carrera will also bolt on to the 968, both caliper and rotor, correct? In the rear the calipers are also interchangeable with the front correct? There is no larger than typical rear rotor commonly available for a 968 is there?
I am trying to create a 380mm front and 355mm rear set up.
