1986 Turbo shutting off
So I finally got my no start issues resolved (changed speed and reference sensors). Then I changed the clutch and slave cylinders and took it for a quick drive to the end of my street.
Now when I start the car it will run for about 5 seconds and then shut down. Before shut down the idle is steady (no coughing/sputtering). The car will restart immediately but then shut down again. No sure if feathering the throttle will keep it running or not.
I don’t think the alternator is charging the battery, but the battery has a full charge. Also the power steering has a sever leak and the reservoir is empty of fluid. I don’t think those two issues would be the cause of the shut down but I thought I’d mention them in just in case there is some sensor that might contribute to the shut down issue.
any ideas on what to start looking at first? I know Fi pretty well, just not the 944 system.
I'd suspect the fuel system. Can you spray some starter fluid into the intake in spurts while the engine is running to see if you can keep the engine going? If it does then I'd recommend doing fuel system checks for fuel pressures, fuel pressure regulator checks and vacuum sources to the FPR. Reference Clark's Garage for system checks.
Regards,
PS: You didn't mention the year, but since you did mention the speed and reference sensors, I'll assume yours is an early model.
Did you by any chance "notch" the bell housing while you were replacing the clutch? If so, earlier models will have problems because the sensors aren't shielded and will pick up noise from other electrical components near them, which can cause the ECU to shut down the engine the way you describe. There's a later model part that's used to shield the sensor(s), you may need to install them if you notched the bell housing.
PS: I've heard rumors that wrapping the sensors in tin foil does the trick too, but I've never tried it.
It ran well to the end of your street? Then just started dying after parking and resting for a while? If so, the reference & speed sensors should be good. I'm curious what you find! Let us know
Well, all good suggestions. As it turned out a small hose had come off a line that was running from the inter cooler to the throttle body. Once I hooked that line back up it was fine.
Not sure how that line line fell off. I wasn’t working anywhere near that area. The end of the hose has marks that show it had a hose clamp on it but there was no hose clamp on it when I found it. See pic below...
