Does anyone have a European Turbo bumper on their car?
If so, could you answer a question about the bumper pad (the black piece of rubber that bolts onto the bumper)? I received one recently, and it only had seven threaded studs along the long portion, but no threaded studs on the corners. There are corresponding holes on the bumper that suggest there should be studs on the corners of the bumper pads. I was told the corners attach with self-threading screws, but that doesn't seem right to me. Porsche has NLA'd these parts, so it's hard to find this info anywhere, so any first-hand experience would be really helpful.
Oh really? So there are seven threaded studs embedded in the pad, but you drill in a self-tapping screw to attach the sides? And the screws are inserted from the outside of the pad? It's just that in pictures of Euro Turbo bumper pads, I don't see any screws on the outside of the corners of the pad. Do the screws go through the pre-drilled holes in the bumper and attach like the threaded studs, with nuts? Thanks!
