924/931/944/951/968 Forum
Auxillary Turbo Coolant circulating pump?
Old 09-02-2018, 03:25 PM
951North
User
951North's Avatar
Default Auxillary Turbo Coolant circulating pump?
I suspect mine isn't working anymore. I don't remember hearing it running for the longest time after the car shuts off. I tried testing the leads with an Ohm meter and i get open circuit. I applied 12vdc with both normal and reverse polarity directly to the motor and nothing. Any tips to resurrect it? Or links to one that isn't $300? Or do I just idle the car for a minute after driving to circulate the coolant through the turbo?
Thanks.
951North is offline
Old 09-02-2018, 11:17 PM
fejjj
fejjj's Avatar
I would just let it idle for a minute prior to turning it off.
fejjj is offline
Old 09-03-2018, 09:08 AM
931guru
User
931guru's Avatar
Audi uses a very similar turbo coolant pump which is a better design and much cheaper. The major difference is the connection, which should be a simple conversion using a connector (much like a fuel injector connector) salvaged from an old harness, etc.
Amazon Amazon
Amazon Amazon
931guru is offline
Old 09-03-2018, 11:31 AM
Dave951
User
Dave951's Avatar
^^ Nice find. Love seeing people find alternative OEM parts from other vehicles that are a fraction of the cost and almost exactly the same. For quick ref its Bosch 0392020073
Dave951 is offline
Old 09-03-2018, 08:51 PM
951North
User
951North's Avatar
Good stuff looks like it would work nicely.
951North is offline
Contact Us - About Us - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
