Can't Install Valve Keepers '87 944S Head
I'm at my wits end. I built a custom valve spring compressor to compress the springs (engine is still in the car). If I place the valve keepers in their tapered hole and compress, they just fall out. There's no room to get my fingers into the recessed hole to place the keepers on the valve. Is there a trick here I'm not seeing?
Thanks,
-Mike
Thanks,
-Mike
What kind of tool...?
I made a sleeve with two windows in it.
I use a magnet to set them generally and a pick to force off the magnet into position.
Rotate the first half away from your best sighted position to make it easier for the second half install.
It helps if you can lay a second magnet (small telescopic in both cases) stuck to the retainer (assuming they are ferrous) which will help attract the keeper.
Good luck.
T
Good luck.
T
Good luck.
T
Good luck.
T
Even a PVC sleeve is strong enough.
Be mindful of the lifter bore, you can easily scratch/gouge it if a loaded metal tool goes astray.
T
Rainman
why are you doing this in the car?
anyway, this might be a good excuse to find a medical supply store and pick up some surgical forceps "pliers" that come in a variety of sizes and angles...they even have little teeth so you can clamp veins or small parts.
have a few, very useful.
Ah, I understand the question now, sorry. Since this is the first engine I've ever built, I did everything but the head myself. I had a shop lap/grind the valves. They told me everything in the head looked good, but due to the rate at which I've been burning oil over the first 5k miles, I suspected that the valve stem seals were bad. Obviously had I known I would have replaced them with the engine out of the car (along with the guides, but those actually feel fine), but now I'm paying for my lack of knowledge.
Maybe you're right though, could be the seals.
Was there smoke...?
Was it on decel or closed throttle puffs during shifts...?
T
