89 944 ABS PUMP RUNNING
Old 04-20-2018, 08:31 PM
mattytemple
2nd Gear
mattytemple's Avatar
Thumbs down 89 944 ABS PUMP RUNNING
Hi all
I went to take the 89 944 for a blast today because the weather in NY finally turning for the better
Upon start up - ABS self test happened but pump continued to pump and whine.
Shut it down and still runs - had to disconnect the battery
Tried to pull the relay = it still runs
tired to pull the plug on the ABS computer = still runs
tired to pull out my hair - still runs
Only thing that makes it stop is disconnecting the battery
Anyone come across this issue before? or anyone have any suggestions. Car has never had issue - perhaps one of the wheel sensors is faulty and giving signal
I only know of the one relay for ABS g20 o any help would be appreciated
Old 04-20-2018, 10:22 PM
PaulD_944S2
PaulD_944S2's Avatar
There is a second relay located on the ABS pump in the passenger side fender well.
Old 04-20-2018, 11:43 PM
jhowell371
jhowell371's Avatar
Thanks Paul for that tidbit of information to be filed away by myself and others with ABS.
Old 04-21-2018, 09:55 PM
mattytemple
2nd Gear
Default Thanks
Paul you’re the man. Pulled the inner fender today. Pulled the relay on the pump. Cleaned it and all systems go.
Thanks for the info. Appreciate it
Quick Reply: 89 944 ABS PUMP RUNNING
