Spring plate bushings
Well I had another shot at it today - it took me all day but I got the polybronze bushings installed on both sides by dropping both sides at the same time. On to the next problem: does anyone have any tips on getting the hidden bolt that goes into the top of the "blade" of the torsion carrier (up inside the wheel arch) into place? I've got it on the passenger side but I can't get it to go into place on the driver's side. Using a mirror it looks like the torsion bar carrier piece needs to come up a little. But I can't seem to get it into place.
This is the one I'm talking about:
Do you have the carrier to body mount bolts loose? I remember having that problem when I saved those banana arm mounts for last, and couldn't get them aligned. I reversed it, and loosened the other bolts and started the banana arms first, it was much easier that way. I had to adjust a transmission jack along with a floor jack to properly get everything aligned and every bolt slipped in and nut started by hand.
You mean the bolt that goes through the big rubber bushing on the spring plate cover? That's loose, although I've tried it both ways, and with that bolt completely removed, but it doesn't help. Right now that bolt is in but not all the way through. I loosened the bolt that holds the rubber bushing to the tip of the blade shaped piece in the hope it would give me more wiggle room, but there still wasn't enough. Maybe I should remove that piece completely.
