16v Clutch kit
16v Clutch kit
About to embark on the daunting task of replacing the clutch on my 1987 S.
Reading various posts here and verifying with the Porsche parts catalog it looks like the 8v NA and the 16v S share the same clutch disk but have a different pressure plate.
Looking at the Sachs(ZF) catalog it looks like the correct kit for the S is KF298-02. This is also the recommended kit for the 8v NA so something does not add up.
I contacted ZF and this was their response:
Anybody have an insight or further information about this?
The correct kit for your '87 944S is KF298-02. Our competitors are offering the same clutch for both the 16v and 8v engines as well. My thought is we have used the higher clamping pressure plate for both models.
I have a new Sachs clutch available which is the same for 8V and 16V. The clamping force on the pressure plate was higher for the 16V kits years ago but now the same kit is used for the 8V too. Looking to get $420 for the kit.
Hello Roka. I am new to this forum but I have worked on my S for some years. A year ago I was sourcing a pressure plate for my S and I was able to find this new old stock pressure plate. The sachs number is on it and it fits S and S2. I had set the current Sachs K298-02 next to this and I cannot see any physical difference in appearance however I am not sure how you would test clamping force. Any other S person have an additional comment?
The more I look into this the more my head hurts.
ZF tells me the KF298-02 is the correct kit for the S. Looking at the autohausaz site they claim that the correct kit I'm looking for is KF782-01 which costs $100 more than the KF298-02 but is not in the ZF catalog.
Then there is the the question of the clutch disk that in the photos of the kit had 4 dark springs, but in your photo and in others on the net there are 6 multi-color springs so I'm not sure what is going on.
Roka, not an area I have expertise with. That said, it is probably worth a call to Paragon Products or Pelican Parts to ask for help in identifying the right kit. I believe the rubber center clutch disc may be NLA from Sachs and definitely NLA from Porsche, perhaps that is adding to the confusion: you'll have to use a spring center clutch disc, as was original to the 924 Turbo if memory serves. I have one in my own car, works fine, no real difference to the driver compared with the rubber center. The photos you see on Autohaus (and other sites) may not be the actual part they'd sell you: they often have this disclaimer. Good luck!
Thank Kevin. The rubber center disk is NLA, not that I wanted to go that direction even if it was available.
Regarding the spring center, viewing both Van's and Jürgen's videos on youtube I see that they are using the 4 spring clutch plate where as other places, like YYC2BANF's photo above, show the 6 spring version. Is this just a more updated version or a different clutch disk altogether?
Hi Roka, I recently put an S engine in my (formerly) 8 valve car, and when I swapped engines I took the pressure plate and clutch off the 8V and put it on the 16V. When I replaced the clutch on the 8V last year I used the Sachs kit. The 8V pressure plate has been fine so far so I'd say don't worry about it.
