What could have happened to the 944 (trans, clutch or something else)
Hi!
So was ready to take my 944 around the block, after the transmission was out. The slave cylinder wasn't installed, because it is busted. Put her into first, started it up, no clutch it really struggled to start. Then it starts up, but it's not in gear... But the gear stick says it's in gear, and it felt like it was in first.
So put it in first, still feels like it's not in gear when it pushed, same with neutral of course.
So, possible outcomes? Gearbox is stuffed? Or something to do on the clutch side?
You don't need to put the car in first to start the car. You don't even have to push the clutch pedal down to start it so not sure why you're trying to. And trying to put it into gear without the slave is asking for trouble. You will break something. Put the car back together correctly and try again. Then you'll be able to tell what's wrong if there's a problem.
Well, if the slave cylinder in your car goes. How do you drive it?
you start it in gear and drive... That's what happened to my golf.
The thing is, my mechanic told me to do this before I drove it up to him like that because he's going to replace the slave cylinder.
His shop.is just up the road, so rather than trailer it I was going to just drive it.
If you are saying you have no connection between the trans and the engine then yes it could be the clutch or one of the torque tube couplers, or it could be a blown ring and pinion in the trans.
You could narrow things down by determining if the torque tube rotates with the trans in gear (and one wheel blocked), you can check at the rear coupler as per:
http://www.clarks-garage.com/shop-manual/trans-03.htm
If that is turning maybe pull the starter and see if you get rubber damper chunks out. Or check at the front coupler?
-Joel.
-Joel.
-Joel.
-Joel.
So it's definitely something in the Trans.
Maybe diff? So start it up in gear (wheels in the air so they spin), spins very slow, only one wheels spins, when I manually spin the wheels i have to hold one to get ANY movement in the input spline.
Whereas yesturday when I did that, 2 wheels spun, and there's a funky noise coming from the transaxle.
Possible issue? Ring and pinion? Diff?
Are you sure it's clunking into gear? Does 1st or reverse produce different results?
I do not know if what you are describing here:
"when I manually spin the wheels i have to hold one to get ANY movement in the input spline"
is normal or not, yes if you have an open diff you need to hold one wheel and turn the other to spin the input shaft of the trans via a wheel. But is what you are seeing just 1st gear or is something blown and you are seeing a little drag between a ring gear and a blown pinion? Or maybe the trans just isn't really in gear?
If you shift to reverse and get a little reverse movement and a clanking from the trans, shift into forward and get a little forward movement and clank clank then it could be a bad pinion or maybe a coupler not in place or left loose and the splines got destroyed or something.
You did say the trans was just out, had it worked before it was removed? Why did it come out?
Have you confirmed that the shift linkage at the transmission is secured properly? Based on your description it might be loose enough so it is not engaging the selector rod all the way to properly shift into a gear. Check the 6mm set bolt that locks the shift linkage in place once slid over get selector rod. Check the 8mm set bolt that locks the shifter rod to the shift linkage as well. If you have play in any of these places you will not be shifting the transmission into any year completely.
