coolant burping and barfing snot
guys
sorry didnt see any thread on this
coolant puking out snot as per video. my engine is running (1986 NA 944). coolant is blue and all clear, then after the burp there's white goo floating
any thoughts? i was thinking maybe headgasket, oil cooler.
Coolant pblms
I would do a pressure check on the coolant system first. If it won’t hold pressure, then you definitely have a problem. What does the dipstick look like? More milkshake/white goo? Don’t run the engine lest you trash the bearings. Drain the oil and check it for water/ coolant. Then go to the ORPV/ oil filter assembly and change all the parts out. You may want to check for exhaust in the coolant as well… you can get a rental kit to do this from Advance or AutoZone. Might save a head pull with all of it’s associated terrors and costs.HTH some.
- cylinder compression test was ok
-test for combustion gases was ok
-spark plugs are ok
-no loss of power while driving
-no milkshake in engine oil
-no white smoke from exhaust
seems like oil cooler issue. ordered gasket set and will change engine oil as well as coolant at the same time. Car parked to prevent further damage
will keep you'll updated on next steps/findings
cheers
Tiger03447 (10-22-2022)
oil cooler removed
An update:
-oil cooler removed
-O-rings perished completely
-Plenty of muck
-You can see the point where oil/coolant mixing
Going to have it cleaned and new gaskets/O-rings installed
-oil cooler removed
-Plenty of muck
