944 S2 Engine noise
944 S2 Engine noise
Just noticed a loud ticking from the underhood, took a video after a cold start. Haven't noticed it until now, it's a high frequency noise that sounds like lifter noise, but wanted to get a second opinion - about to drive to SoCal from the Bay and don't want to do so if it is rod knock! Car is a '90 S2 with 115k miles. Timing belt done fairly recently.
Hard to tell from the video, but sounds pretty much like the normal S2 engine sound.
As V2 stated, the injectors are fairly loud.
Since you have a concern that it might be rod knock; how is the oil pressure, and have you listened to the oil pan area under the car?
