924/931/944/951/968 Forum
Supercharging a 944 - Why so hard?
Old 12-07-2017, 12:33 AM
  #106
odurandina
Slayer of Economic Optimism
odurandina's Avatar
Location: one thousand, five hundred miles north of Ft. Lauderdale for the summer.
I recently drove a 100% California smog legal LS3 996.
I'm told it's the first fully legal LS swapped Porsche.
Amazing, sorted swap.
odurandina is offline
Old 12-07-2017, 08:21 AM
  #107
Tiger03447
I think that the tiny Nippendenso models that go on an early Honda FIT put out about 90 amps...They are only about 4 inches in diameter..might be a solution to tight quarters...jus sayin..
Tiger03447 is offline
Old 12-07-2017, 11:23 AM
  #108
V2Rocket
Rainman
V2Rocket's Avatar
TonyG had a 100% legal swap before the LS3 even debuted, lol
V2Rocket is offline
Old 12-07-2017, 11:25 AM
  #109
jderimig
jderimig's Avatar
^ Like. I will search.
jderimig is offline
Old 12-11-2017, 03:43 PM
  #110
jderimig
jderimig's Avatar
Last I removed the airbox to survey the room I have, I have plenty.
Spencer: Do you know if an alternator can be driven with a single v-belt? Thinking ahead of moving the alternator to the PS place but still use the PS crank pulley.
jderimig is offline
Old 12-11-2017, 03:50 PM
  #111
V2Rocket
Rainman
V2Rocket's Avatar
that's how i was going to do it, using the PS pump drive pulley and a v-belt pulley from an old volvo or something on the alternator.
"serpentine multi-rib" belts only really came about in the late 1970s...before that everything was "single V belt", alternators, mech fans, AC compressor, power steering, etc.
V2Rocket is offline
Old 12-12-2017, 03:20 PM
  #112
jderimig
jderimig's Avatar
So I put together a rough budget for this project. Prolly left a few things out which I will compensate for by adding 50% to my estimate which may not be enough. But here goes.
ECU $609
MS3 $409
Other sensors $50
Wideband O2 $150
SC $690
MB M62 $170
Custom Pulley Set $270
Water Inj $150
Tube Fab $100
Alternator Relocation $150
Smaller Alt $100
Bracketry $25
Pulley Mods $25
Electric PS conversion $135
Volvo S40 PS Pump junkyard $50
Fittings $25
Elect $35
Mounting $25
Total $1584
jderimig is offline
Old 12-12-2017, 03:25 PM
  #113
V2Rocket
Rainman
V2Rocket's Avatar
Probably in the ballpark, but IMO designing in a proper intercooler is a better idea than water inj.
It's a cool idea, and it definitely works, but having to refill a tank and having another semi-complex system of switches and pump(s) sounds like a PITA.
Check out these guys for a pulley, I sent them a stock Ford SC pulley to get dimensions from, and had them make me a custom larger (to get underdrive) lower-boost pulley for ~$160 shipped.
I bet if you sent them your MB pulley they could whip up a solid (non clutch) version to fit your needs.
http://www.southfloridapulleyhq.com/
V2Rocket is offline
Old 12-12-2017, 03:37 PM
  #114
jderimig
jderimig's Avatar
The shaft on the MB M62 is splined which is a deal breaker for many of these after market companies. I'll send them an email though and ask if they can do one.
jderimig is offline
Old 12-12-2017, 03:48 PM
  #115
V2Rocket
Rainman
V2Rocket's Avatar
then perhaps the solution is to have the MB nose shaft turned on a lathe to remove the splines, and make it (if possible) the same OD as the GM-style pressfit pulleys.
V2Rocket is offline
Old 12-12-2017, 03:49 PM
  #116
jderimig
jderimig's Avatar
More on the pulley cost
The $269 includes 2 pieces. The splined hub that mounts on the shaft, and the pulley that mounts to the hub in a "quick change" arrangement. New pulleys after that are less than $100 (from Hungary.....)
jderimig is offline
Old 12-12-2017, 07:01 PM
  #117
jderimig
jderimig's Avatar
You are probably right but I want to avoid the ducting and fabbing. Running a 1/8" nylon tube from the washer fluid tank to the SC output sounds easier to me fab wise. At the boost levels I am targeting I probably do not need IC so this is just R&D and play for me. I would be running the injection off MS3.
Now for fun project afterwards I was thinking of using the AC (its right there) to do the intercooling. Fashion up a small evaporator and expansion valve right at the SC output and pump the refrigerant up there. With a 40F evaporator you do not need a very big heat exchanger. Have a valve actuated by the ECU or vacuum to direct the refrigerant to the cabin evaporator when off boost. Should work right?
jderimig is offline
Old 12-12-2017, 07:25 PM
  #118
V2Rocket
Rainman
V2Rocket's Avatar
Ford tried that on the Lightning as an optional extra.
They use the AC to passively cool the water in the air-water intercooler system while driving around so it gets super cold. Then when you actually go into boost the water is at 35 degrees or whatever rather than roughly ambient which helps a LOT in cooling efficiency.
You could do similar with your to-be-injected water.
If you want to directly "air condition" your boost, not gonna work.
The 944's AC system takes 8-10hp to cool ~300 cfm from the blower fan from 100 degrees down to 65 or so in the cabin.
Air coming out of the blower will be 250+ degrees, lol, and the compressor turns off when you got WOT
V2Rocket is offline
Old 12-12-2017, 07:57 PM
  #119
jderimig
jderimig's Avatar
Good to know, saves me some work.
jderimig is offline
Old 12-13-2017, 03:14 AM
  #120
ealoken
Why dont you guys just use a stock 951 cooler? It fits right in the nose, and will do the job for your SC engines
ealoken is offline
Quick Reply: Supercharging a 944 - Why so hard?
Contact Us - About Us - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
