924/931/944/951/968 Forum
Supercharging a 944 - Why so hard?
Old 10-24-2018, 12:52 PM
  #241
jderimig
jderimig's Avatar
Originally Posted by V2Rocket View Post
nowadays there are lots of options for electric PS pumps, or electric-assisted racks....something to consider.
there are even electric AC compressors but those tend to need much higher power capacity (48V or LOTS of amps) to run.
Yes, I do have a Volvo C40 PS pump. Trying to figure how to mount that. That was my first idea on how to keep AC.
jderimig is offline
Old 10-24-2018, 12:55 PM
  #242
jderimig
jderimig's Avatar
[QUOTE=mdnt08;15382873]
Originally Posted by jderimig View Post
In reading some MB230 specs, the crank pulley might be 6.1" Isn't the 2.58v's crank a 5"? Do the math, I don't think the existing pulley will drive it hard enough.
Yes I will need a custom M62 pulley around 80mm for the modest boost level I am going for. There is a gentleman in Hungary who makes those.
jderimig is offline
Old 10-26-2018, 03:41 PM
  #243
jderimig
jderimig's Avatar
I took a look at my Volvo ps pump for fit again. If I cut off some mounting ears it may fit where where the stock PS reservoir goes. However the pumps reservoir is too tall. If I 3D print a shallow custom reservoir it might work.
The only question is how much fluid do I need in the reservoir? Do I only need enough that fluid stays above the intake at all times?
jderimig is offline
Old 11-07-2018, 09:36 PM
  #244
DarrenD
DarrenD's Avatar
My brother is looking to sell my entire Supercharger setup if anybody is interested. It is not a kit but comes with everything you need to supercharge a 944(with some minor/major mods)
Comes with DME(Rogue) with tuner and logger.
Rogue NA-Tune with custom stainless MAF tube
Eaton M90
Top view of where the SC was fit.
SC Mounting bracket
Intercooler and piping
and much much more.
Its a great way to get started, most of the hard work is done. around the $1700 range for everything.
DarrenD is offline
Old 11-08-2018, 11:59 PM
  #245
Noahs944
Super User
Noahs944's Avatar
That is a deal DarrenD.
Beautiful fabrication!!!
Noahs944 is offline
Old 11-09-2018, 04:14 AM
  #246
odonnell
odonnell's Avatar
Would you consider selling that without the NA-tune and rogue gear?
odonnell is offline
Old 11-09-2018, 12:42 PM
  #247
DarrenD
DarrenD's Avatar
Yes I would.
DarrenD is offline
Old 11-24-2018, 08:00 PM
  #248
Dwizle
User
Dwizle's Avatar
Default ​​​​​​​Facebook post about Sc kit for NA's
From facebook
Aaron Hafer
New Member · November 20 at 6:41 PMWhat kind of interest would there be for a bolt on roots / twin screw type supercharger kit for the Porsche 944? Pricing starting probably somewhere around $1800 without engine management.
Dwizle is offline
Old 11-26-2018, 04:49 PM
  #249
jderimig
jderimig's Avatar
Nice, it claims to keep the AC also. His later post shows he is using the MB62 roots.
jderimig is offline
Old 11-26-2018, 08:50 PM
  #250
DarrenD
DarrenD's Avatar
That image is of a TPC SC kit for a 996
DarrenD is offline
Old 11-26-2018, 10:13 PM
  #251
MAGK944
MAGK944's Avatar
Originally Posted by Dwizle View Post
...Facebook post about Sc kit for NA's
Thats not a 944 SC kit and from his FB posts it doesn’t seem he has even created a working prototype let alone a fully tested kit.
MAGK944 is offline
Old 11-27-2018, 09:54 AM
  #252
jderimig
jderimig's Avatar
And yet there seems to be a long line of people wanting to fork over $1500 to $1800 on vaporware. I am in the wrong business.
jderimig is offline
Old 12-25-2018, 11:01 PM
  #253
944 Lachlan
944 Lachlan's Avatar
And so it begins...
944 Lachlan is offline
Old 01-04-2019, 01:09 PM
  #254
944 Lachlan
Look what I pulled! I may have started a hoarding problem.
Thinking about using one of these IHI twin screws vs. an M90.
Advantages:
Higher boost potential (I need that at 7000 feet)
More efficiency (~64% adiabatic efficiency at 1.8-1.9, vs 62% at 1.4 for the M90)
Less heat
Cool factor
Thinner form factor may fit better
Sound?
Disadvantages
Harder to find refurb parts
Less volume per Rev (~73ci)
Has to be plummed to oil supply
Given the potential to drive it harder, I'm no too concerned about the volume defficiency. Tapping the engine for oil shouldn't be too hard, but mating it up to the supercharger may require some creativity. Do you think I could turn it into a sealed unit?
Old 01-04-2019, 01:13 PM
  #255
V2Rocket
Rainman
V2Rocket's Avatar
Lachlan - still digging for those parts I owe you.
Those Mazda units are super cool, I thought about those once (I also owned a Millenia 10 years ago) but the lack of parts was my concern.
Millenia S owners have to buy new ones at $3k apiece if their original one pops, but you might be able to scavenge parts from multiple units to make a solid one.
73ci per rev is still plenty for a 944 motor that takes 75ci/rev at 100% VE...just add overdrive to the blower.
The skinnier case will be a huge help in packaging.
V2Rocket is offline
Quick Reply: Supercharging a 944 - Why so hard?
Contact Us - About Us - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
