Supercharging a 944 - Why so hard?
Old 01-08-2018, 05:33 AM
  #181
mdnt08
mdnt08's Avatar
Originally Posted by Alr11606
When I looked at using a Eaton m62 or m90 I found I was going to have to cut the snout almost to the bearings just to have enough room to bring the inlet elbow around. Plus the throttle would need to be on the elbow and near the front. Creating a super long path which may hurt response. Now mounting the "to the side" and not directly to the intake would make plumbing a bit more complicated but allows an intercooler and the throttle response should be like factory.
this was how the thunderbirds were set up.
When I cut the m62 from the GM Cobalt to fit a 90 cast elbow on it, it was about 1 inch from the needle bearings. Given this is one of the longer SC, I'd say any other should fit unless we are trying to fit a m112 with a long pulley nose.
Old 01-08-2018, 05:47 AM
  #182
mdnt08
mdnt08's Avatar
Originally Posted by jderimig
Yes I have seen it argued both ways on the endless "hot rodding" forums. I was hoping that I can use a bypass valve arrangement to get this to work with the TB after the SC. Could that work?
I do not plan to use the clutch. I will remove it and replace with a quick-change like pulley thingy.
Edit: After more research I will try and mount the TB before the SC.
My TB is still in between the plenum and IC, the only draw back I found was the larger diverter valve needed when you are off-throttle and in gear at a high rpm. People said it would create more heat due to the SC....have not noticed it. I may move it to see, but it's doable without moving it for low boost set ups. The bypass is a must tho.....
Old 01-08-2018, 05:51 AM
  #183
mdnt08
mdnt08's Avatar
Originally Posted by V2Rocket
i have VEMS ECU so i can use whatever injector i want.
i have a set of 55lb/hr and a set of 72lb/hr on the shelf. i'm sure there's a 3 or 3.5 bar FPR that will fit the NA rail, haven't looked too much at it since these injectors are more than big enough to work at stock 2.5 bar.
I used a Bosch 3bar FPR for a turbo Saab, inexpensive and it bolts right on....looks identical...other than the part # and pressure.
Old 01-08-2018, 05:57 AM
  #184
mdnt08
mdnt08's Avatar
Originally Posted by DarrenD
I used the factory Bosch valve from the 944 turbo, it worked well. It's actuated when the motor is running in vacuum(cruising). That is it spliced into the intake.
Second that, I'm using 2 Bosch style diverter valves for a vw/audi. Metal housing ones can come with different spring rates.
Old 01-08-2018, 06:00 AM
  #185
Ish_944
Ish_944's Avatar
Could you post a link to it?
Which fuel rail do you have? One of the 2 early styles?
Old 01-08-2018, 06:01 AM
  #186
mdnt08
mdnt08's Avatar
Seems very competitive with centrifugals. I have seen Whipple W100AX (97 ci/rev) discounted to ~$2100. Par with Rotrex, cheaper than ProCharger. Smaller than a M90 (maybe a little longer 14.6" with shortest stock snout) . Seems like the ideal unit for a 2.5L. What's the downside other than cost?
That's why the GM LSJ m62 or 5th gen is not a bad one to use. It's a more efficient roots, kind of under the twin screw...but much less costly.
Old 01-08-2018, 06:12 AM
  #187
mdnt08
mdnt08's Avatar
Uh...the one that the fuel line runs my the brake booster?
https://www.ebay.com/itm/BOSCH-02801...72.m2749.l2649
Old 01-08-2018, 11:50 AM
  #188
jderimig
jderimig's Avatar
Do you have a pic that shows the fit of the Cobalt M62 in your engine bay?
Old 01-08-2018, 11:59 AM
  #189
jderimig
jderimig's Avatar
A basic question on SC ratings. Roots blowers are volumetric devices. An M62 gives about 62 CI of air per revolution. But is this rating based on the input air temperature or the outlet air temperature for the purpose of calculating the mass flow?
Old 01-08-2018, 12:07 PM
  #190
V2Rocket
Rainman
V2Rocket's Avatar
John, it moves 62 ci (volume) per revolution, period.
Mass flow will vary based on inlet temperature and outlet restriction.
62ci at 0*C is still 62ci at 100*C...
But those 62ci weigh less at 100*C.
I really don't think you need to waste time calculating that stuff - the SC will be pulling in ambient air from the air filter just like an NA car, so inlet temp should be the same.
The blower is going to move the air, no matter what - you need to focus on cooling the air down AFTER the SC.
Old 01-08-2018, 12:28 PM
  #191
jderimig
jderimig's Avatar
John, it moves 62 ci (volume) per revolution, period..
Ok, to make sure I understand... Assuming no inlet restriction I get 62CI of air at inlet density per revolution. Assuming no leaks we then will get that equivalent 62CI inlet conditions forced into the cylinders.
Then all intercooler does (on a positive displacement blower) is to reduce air intake temps to prevent detonation? In other words, hypothetically, if I am not detonating without an IC, then adding the IC has no other effect?
Old 01-08-2018, 12:31 PM
  #192
mdnt08
mdnt08's Avatar
Initial cut before figuring out how to better shape and cap the end.
The oem bracket for the alt and ac was completely removed and I reused the mounts replacing it with a steel tube frame to lower the alt and let the SC sit as low as possible.
Fitting with TB in front of SC. Eventually moved it back between the plenum and IC for other reasons.....i think both can work if the bypass flow is big enough.
About to cut out the NA nose to fit IC
The framing was way to narrow to fit the piping I wanted, so the radiator had to move down a bit.
Lowered radiator mount extension with aluminum bolted to welded extensions. Top angle bar to protect the radiator and stiffen the sub frame.
How it is now.
Another angle. double diverters...not recirculated.
Top view to see the orientation.
Old 01-08-2018, 12:41 PM
  #193
mdnt08
mdnt08's Avatar
Well in the end you should be able to produce more power by being able to run a higher ratio pulley set up (that will increase the air temp) and add back timing that will produce much more power......kind of a big difference.
Old 01-08-2018, 12:42 PM
  #194
V2Rocket
Rainman
V2Rocket's Avatar
looks awesome!
Old 01-08-2018, 12:48 PM
  #195
mdnt08
mdnt08's Avatar
looks awesome!
Thanks, hoping this will help others to get motivated that when certain aspects are carefully understood..it can be a stable set-up.....take advantage of that VEMs so we can figure out how to best tune and mod the config.
Quick Reply: Supercharging a 944 - Why so hard?
