1986 NA Engine Stumble
Hey all,
So my 1986 NA 944 was running well recently. I recently replaced the battery, the plug wires and the crank position sensor (all back in Spring). I gave the car a bath last night, and right afterward tried to start the car. The car has a bad stumble, almost like it is on three cylinders. I'm wondering if water got somewhere that it shouldn't and is causing the issue (seems like too much of a coincidence). Can anyone suggest where I should be looking for accumulated water? Anything else I should check before towing the thing off to the mechanic?
