New 1983 944 Owner/ Maintenance to cover
Hello all! I just purchased a 1983 Porsche 944 (unknown miles, over 100,000 if I were to guess. Runs like crap, but does run. The good news is the underside is in fantastic shape along with the body (will need paint though). I've looked at the engine and it is well used.
What are the most important suggested repairs. I've just ordered new oem plugs (owner had iridiums in it), new aftermarket fuel injectors (has originals), new air J tube (original and coated in cracks), used airbox from Ebay (previous owners thought they were race car drivers and just attached a cone oil/air filter), new fuel filter, new engine mounts (you can feel every vibration through the car), plugged the open tube hole on the cambelt cover (yes, the tube was removed and left open to the elements ((sigh)).
I am planning on doing a cylinder compression test to check that status (don't really want to pull the engine if I don't have to)
After some reading, I know I will need to replace the cam belt (as I have no idea how old it is, and there is a whine noise when the engine runs that gets louder with rpm increase). It looks like all of the air hoses need refreshed (pretty sure that's why the engine surges), oil cooler seal replacement (oil under the engine and some oil in the cooler overflow tank), oil separator seals replaced (oil residue in the intake tube), possibly rod bearings since the previous owner complained of the car dying after warming up (which I have not experienced).
WHAT ELSE?!!! Am I overlooking anything else that is important? Thanks for the help! I am actually stunned that a 35 year old car that has been through the ringer so much still runs. A true testament to Porsche manufacturing.
Pics show the one spot of rust on the hood which I have already covered with primer to stop the spread and that open hole I plugged (cut off the handle on a small garden trowel, ha!)
Wow, looks like you have no balance shaft belt on there. Pull the covers and get an idea of whats going on in there. Start with timing belt, water pump, rollers, fuel pump, filter, cap, rotor, plug wires.
Try to find the original intake snorkel also, that filter is not doing the motor any good.
Congrats!!
Congrats!!
Congrats!!
Congrats!!
Pretty sure I looked at this car near the air base in G.Forks, ND a couple years ago. If not it, has to be it's clone right down to the color, phone dials, and missing hood pad. It was wearing Carolina plates at the time and I walked away because it had wet floors. Two inch deep water inside and other issues. Seller was stuck @ 1800.
Hope you got him way down on the price.
It is savable ( everything is, even crumbs on the prairie like the '62 Cabriolet located about 10 miles away from this car --- possibly. Which had sat on alkalai ground for 40 years and looked like a screen door about 6 inches up. After a 200,000 + restoration, and 4 years of blood and sweat, it's a show queen and winning trophies. )
I wish you well in your endeavors. Don't lose hope; you've come to some good resources here.
