Solid Bushings?
Solid Bushings?
Hey all,
About a year and a half or so ago I took the plunge & rebuilt the entire suspension on my S2 with one of the Racer's Edge delrin/polygraphite bushing kits. Forget what it was called. Anyways, it's been squeaking pretty bad from the rear for quite a while now and it's starting to drive me crazy. I'm fairly certain it's the lower spring plate bushing but I'm not 100% sure (I circled it in the picture).
I've been considering just making the jump to metal bushings throughout, both for performance and lack of maintenance. I'm getting more and more serious about autocross and while it's my only vehicle, it only really sees 1-2 road trips a year to see family and the odd weekend jaunt up the coast in the morning with some other sports car buddies, some errands around town once in a while etc.
Are they really much of a jump from delrin bushings in terms of ride, noise? I just worry about tearing apart the rear of the car again and miss fixing the squeak, just to do it all over again and waste more time. Slippery slope to Hoosiers, no back seat and a cage..
Did you replace the spring plate bushings with delrin ones?
The bushing that you have in the picture will affect minimally the performance of your vehicle and it doesn't really make any noise if it fails.
I did. That's probably what it is. I just thought that the lower bushings were squeaking because I had a bit of a hard time getting it to fit back into the car when I was putting it all back together.
I recommend replacing the Delrin spring plate bushings with the Poly-Bronze bushings made by Elephant Racing. I had the Delrin bushings for years on my track car and they were noisy and started to bind. Then, I installed the Poly-Bronze bushings and the difference is significantly noticeable. The noise disappeared and the motion of the trailing arms is smooth within the whole range without any binding.
If you are doing sphericals anywhere and drive on the street, make sure to get weather sealed type.
T
There is, or was, a teflon-based lube Automotion sold that was very helpful in curing squeaks from plastic (Delrin, etc.) bushings. This grease or this one might do the trick.
If you switch to the solid mono-ball type bushings, your car is going to ride worse, be noisy as hell and every little crack in the road will be felt and heard through the whole car. My 968 had these bushings on it when I bought it and while it handled great, its awful on the street. I drove the car across country and can't wait to pull it apart and put the stock bushings in. Once I pull them all out and replace them with new stock bushings, you can buy my old one if you want.... Also have front and rear coilovers
NOTE: If I don't remember to get back to you guys, please PM me. Thanks!
