Supercharging a 1985 944 N/A - POSITIVE FEEDBACK ONLY!
#46
With all that, I must comment on the beauty of the alternator mount..looks like it was CNC'd. Nice welds too...perhaps it's just an optical illusion, but does the blower belt line up with the other pulleys well? Looks like the blower is set too far forward in it's relation to the other pulleys..?? No Gilmer timing belts here..LOL!
For crank and alternator pulleys I see lindsey racing does a 6 rib pair, this may be sufficient, plus given most of us may use a larger underdrive supercharger pulley to keep boost sensible, this should increase belt grip across the fewer ribs. If anybody has a source or reccomendation for these please chime in
#47
Rainman
more ribs is better if you can get them, but keeping the physical size of the pulleys large helps too for grip.
this includes both the crank drive pulley, and the pulley on the supercharger.
#48
Is it possible to add a supercharger and keep the A/C? If so, which would better fit the engine bay in that application, something like the Eaton m90 or a centrifugal? I'm not looking for insane power numbers, just something to add a little pep to keep up with modern traffic.
#49
Rainman
That's what I was trying to accomplish with my bracket posted previously...but it would require eliminating power steering to put the alternator on that side of the engine.
There are kits out there (speedforce racing, 928motorsports) that use centrifugal blowers that allow you to keep AC.
#50
My first 44 had leaky power steering so i just disconnected it. It was a bit rough in parking lots, but fine in all other instances. I'd rather have a/c than power steering. V2, would your mount require fabrication skills to make?
#52
