No start after engine swap
I took 2 years to complete an engine swap now car won't start. It's a 1984 944 2.5L Base. I just replaced the DME relay and put in a refurbished ECU. Still no start. There was no pulse to the injectors and no power to the coil. It has brand new plugs, wires, and distributor cap. Sounds healthy when it turns over. My next thought is to replace the wiring harness. Any other ideas?
I wouldn't throw parts at it. Get a schematic and a meter, or at least a test light, and figure out what's going on.
And welcome.
Right. I'd start with the basics. If there is no fuel or spark, then start by confirming you have power and ground at the DME. If that checks out, then look for speed and ref sensor pulses (tach bounce). And so forth...
Thank you
Thank you all for the ideas, keep 'em coming! F18REP, when you say corn syrup, do you mean bad gas?
I am really hoping to get this beauty back on the road! I need all the help I can get!
Also, under the hood, pretty centered in the wiring harness, back against the fire wall, I have a male/female plug that has no mate. Any idea what this is and if it may be part of my problem? It is male on one half and female on the other. I believe it has a red and a black wire going to it, but as I am not looking at the car at the moment I can't be sure.
Hmm, I'm in western Washington, I checked the fuel about a year ago and it seemed okay, but it is possible that it has gone bad. The car does sit outside. Would that actually stop it from starting?
If you can get it to even fire on 2 year old gas you'll be lucky. When I drained mine, the syrup came out first, then some stinky liquid that was similar but darker than regular gasoline. With the 944, you can pull off the tank-to-pump hose and it will drain really fast - be ready with something to catch it. Of course you can just put your thumb over the hose and maybe jam a big bolt or something in to stop the flow but its a potential mess. Many have been through this so search can maybe answer a lot of questions....Bruce
