Screws for sensors on 944 Turbo flywheel
how many screws (Allen head) should there be on a 944 Turbo flywheel?
i've just picked up a used one to speed up a clutch change (will swap in resurfaced, balanced and lightened flywheel rather than wait to get old one done), and it has three of them. Is that right?
i believe one is for TDC, one for a some kind of no-longer supported Porsche diagnosis tool, but the third?
it's an 87 UK model, btw. I'd compare it with the current flywheel, if it didn't have the rest of the car wrapped around it ;-)
On a stock flywheel there are 3 however you only need one (and apparently most aftermarket flywheels only come with one). See this thread and the link to another thread in the 2nd post: https://rennlist.com/forums/944-turb...gger-pins.html
