924S rims - Page 2 - Rennlist - Porsche Discussion Forums
924S rims
Old 09-23-2017, 06:49 PM
Holytin
Originally Posted by Ont924s View Post
So I took the 16 x 7 rims with the 65 offset to the local tire shop for installation. According to the shop the tires will fit the rims but the new rims will be too close to front suspension. The shop made the determination without mounting the tires.
Mount the rims w/o the rubber and install on the car. You should be able to get a dimension using a straight edge to determine whether or not they will fit.
Holytin is offline
Old 11-16-2017, 07:12 PM
kmascotto
kmascotto's Avatar
i mounted a set of 944 turbo s rims on my 81/ [email protected] 7x16 ET 65 with 225/50/16 tires on the front with 7mm spacers and 9x16 ET 60 with 245/50/16 tires on the rear...the rear needs a couple of minor mods for clearance on the tires inside but they fit
kmascotto is offline
Old 11-20-2017, 11:52 AM
kmascotto
kmascotto's Avatar
Default before and after
the stock 15 inch rim
9 inch 944 Turbo S rear rim
Related Topics
Thread
Forum
Replies
Last Post
jlusby
Cayenne 958 - 2011 -->
10
08-11-2017 01:19 PM
Ont924s
924, 924S and 931 Forum
7
05-24-2017 02:36 PM
dkasserra
928 Forum
7
04-06-2016 10:09 PM
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Copyright ę 1998 - 2017 Rennlist.com We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
  • Ask a Question
Question Title:
