924 and 931 Forum 1976-1988
Air Meter Mounts
Old 04-20-2017, 12:44 PM
discocontented
discocontented's Avatar
Default Air Meter Mounts
Does anyone have a source for the rubber mounts which secure the air meter mechanism and fuel dizzy? They are rubber with threaded rod on either end. It doesn't seem like the rod goes through the rubber but is attached to a piece of cupped sheet metal which is supposed to be attached to the rubber part. Two of mine (the front) are broken.
Thanks!
Erik
Old 04-22-2017, 09:30 PM
V2Rocket
Rainman
V2Rocket's Avatar
this one?
http://www.pelicanparts.com/More_Inf...703-260-00-OEM
you might get lucky at your hardware store, finding a threaded rod and a stack of rubber washers instead.
Old 04-23-2017, 08:07 AM
thomasmryan
thomasmryan's Avatar
You can see if the dimensions of the diesel merc air filter mounts would function.
These are the cheap melye ones.
http://www.ebay.com/itm/3-Mercedes-W...9W-94f&vxp=mtr
Old 04-24-2017, 02:04 PM
discocontented
Thanks for the great suggestions!
Quick Reply: Air Meter Mounts
