LED Tail/Brake/Backup light replacements
Anyone tried LEDs for the backup/brake/tail lights like Sylvania Zevos? They're on Amazon, not some random off-brand, and aren't too butt-hurtingly expensive...
If you have cruise control they won't work as brake lights, other use OK.
The cruise control uses a very small current thru the regular incandescent bulbs and the LEDs will glow dimly. |
Originally Posted by PaulD_944S2
(Post 15593239)
The cruise control uses a very small current thru the regular incandescent bulbs and the LEDs will glow dimly. Take the 50w 6ohm resistor and screw it to top underside of trunk just under third brakelight the wire it inline with the third light. That baby gets hotter than a 100 watt bulb so make sure its on metal. The lights flash ok now and none stay on unless car is on. Works really well and looks like a 2015+ car now. Haha Best part is with full lights on I get only .1 volts drop off battery where before with incandescent I was getting like 3 volt drop. The more I would brake in stop and go traffic the more the battery would die. Now it just sits at 14volts charging all the time lights on or off |
