924 and 931 Forum 1976-1988
Starts with fuel pump relay jumpered, but not with brand new relay
Old 03-13-2018, 05:14 PM
Andreas Ledet
Andreas Ledet's Avatar
Default Starts with fuel pump relay jumpered, but not with brand new relay
Hi everyone
My 1980 N/A 924 died on me a couple of weeks ago - it simply wouldn't start, even though I had driven it 200 miles the day before.
I could tell the fuel pump wasn't running, so I turned my attention to the dreaded fuel pump relay. And sure enough - with a jumper between the 30 and 87 ports, the fuel pump came on and the car fired up just fine.
So I assumed I just needed a new relay, and went and ordered a new one just like the one that was in the car before - the 3.300.300 type.
But after receiving the new relay and installing it in the car, it still wouldn't start. Put the jumper back in, and it started.
So I guess the relay is not at fault after all? What else could be causing a problem like this?
Bonus info: Before I had this problem, the fuel pump always came on when the ignition was on. Meaning not only when the engine was turning. I believe this is not the way it was meant to work in its stock form. But that shouldn't have anything to do with it, right?
Old 03-18-2018, 09:02 PM
curtisr
curtisr's Avatar
Have a look here: http://www.924board.org/viewtopic.ph...ighlight=start
Old 03-26-2018, 02:03 AM
V2Rocket
Rainman
V2Rocket's Avatar
Ignition switch could be screwy.
$6 for anew one.
Quick Reply: Starts with fuel pump relay jumpered, but not with brand new relay
