1987 924s heater outlet pipe question - Rennlist - Porsche Discussion Forums
Old 09-28-2017, 02:37 PM
Johnny Barbieri
User
Default 1987 924s heater outlet pipe question
Hi there, I am new to the forum. I am the proud new owner of a cornfield find 1987 924s that I am in the process of resurrecting. In the process of removing the heater control valve, I noticed that the heater outlet elbow pipe located under the #4 intake runner has two nipples on it with rubber fittings on them. One of the fittings is connected to a thin plastic line that runs along under the intake manifold and the other fitting has nothing but a rubber elbow on it and I can not find a loose line that would connect to it. I've had the car running and other than a rough idle it runs like a champ.
1. What are these two nipples on the heater outlet pipe for?
2. Would the rough idle have anything to do with the missing plastic line from one of the fittings on the heater outlet pipe?
Johnny Barbieri is offline
Old 09-28-2017, 06:03 PM
V2Rocket
Rainman
V2Rocket's Avatar
commonly known as the bunny ears, it's part of the EVAP control system.
basically, one "ear" goes to the nipple on the throttle body ahead of the throttle plate.
the other "ear" connects to the vacuum pot/valves located on the driver side inner fender, above the brake booster/clutch master cylinder.
"thermost. valve in coolant circulation" right side of diagram..
V2Rocket is online now
Related Topics
Thread
Forum
Replies
Last Post
skpyle
928 Forum
26
10-19-2017 01:31 PM
FRporscheman
968 Forum
20
07-17-2017 02:32 PM
TheOtherEric
993 Forum
60
11-27-2016 08:47 PM
fiily
924/931/944/951/968 Forum
11
08-07-2016 09:58 PM
jbob
5
06-30-2016 11:33 AM
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Copyright ę 1998 - 2017 Rennlist.com We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
  • Ask a Question
Question Title:
