914/914-6 Forum 1969-1976
Help... White Smoke, Rough Idle, Cut Harness
Old 05-15-2017, 05:46 PM
xicema17x
xicema17x's Avatar
Default Help... White Smoke, Rough Idle, Cut Harness
Hi All,
Curious if you might be able to identify the pix below. The car sat for quite some time, and my assumption is the previous owner did not know how to do an oil change. **The car was spitting out white smoke, which I believe is due to an overfilling issue?**
Anyhow, I took out some oil, and it helped. Now I am in the position where the car seems to run very rich, and my assumption is the cylinder head temp sensor is missing or not functioning properly.
Can anyone help identify if the cut wire below, if it is the temperature sensor wire? Also, can anyone help identify the white plug below please?
Quick Reply: Help... White Smoke, Rough Idle, Cut Harness
