Need help to design a fuel set-up
Here is what I have - 1974 race car body - 1973 2.0 liter very stock inside - pair of p11 (40) solex carbs - 16 gal fuel cell - and a VERY TIGHT BUDGET -
I think I want 2 cheap fuel pumps on board - flex lines thru the heater duct area - and CHEAP - the fuel cell has a -8 an outlet -
this car is for the www.chumpcar.com racing series of low cost, LONG endurance races -
thanks for y'alls help - live in Savannah but NOT from here !!!!!!!
Rennlist Hoonigan
which cost no drachmas
what are the fuel line rules for chumpcar?
You could do a -8 to barb fitting, then just run regular fuel line to the pump and back to the carbs.
Don't think there is much in the chumpcar rules. We built and ran a 325i for a chump race a couple weeks ago. They let you use the stock fuel tank, and naturally fuel cells are allowed. i do recall some subpoints relating specifically to fuel cells though. From what I experienced, they're usually pretty cool as long you don't have a leak.
Rennlist Hoonigan
You need one of these http://www.racerpartswholesale.com/p...cet_Fuel_Pumps and something like http://www.jegs.com/i/JEGS/555/10058...ductId=1167165. You need around 3 psi pressure and and 1/4" line most likely. It's normally mm line, but you can make it work.
Official Wednesday AM Red Bull F1 test driver
Have the Facet pump and an inline pressure regulator on my Weber carbed car- works great- the pump is up front to stay away from engine heat...
thanks dudes - can you give me a run down in words...... cell to filter ---- to pump ----- to rear of car ---to regulator --guage --- Y ---- carbs
what did i miss - in wrong order ------ thanks
