Brakes - is there a difference?
Hi all,
In my efforts to persuade a lot of metal oxide to impersonate a car again I've got one problem that the photos in the magazines just can't answer....
What is the exact difference between the rear brake caliper of a 914/4 and a 914/6 ?
All constructive comments appreciated !!
The rear of the 914-4 is the same as older 911 (pre-1969). The 914-6 is the same as any rear 911 since 1969 up to and thru 1989. The pad shape is the same but the pad area is about 30% smaller...of course all of the 914 rears have the upper pin hole drilled larger to accomodate the larger pin. Does anyone know why they have a larger upper pin? Is it due to the emergency brake system being part of the caliper? I have wondered about this unusal pin for years.
Pete
Pete
