914/914-6 Forum 1969-1976
Correct fuel pump for a 1976 914 2.0
Old 04-28-2024, 09:07 AM
Carrera51
Carrera51's Avatar
Default Correct fuel pump for a 1976 914 2.0
I'm helping a friend get his 1976 914 running. It appears the fuel pump died since it doesn't make any noise when we turn the ignition on. The car since has it's stock fuel injection. Getting ready to order a fuel pump and not sure which one to order. Do the 2.0L engines use the same fuel pump as the 1.7 and 1.8 with fuel injection?
I don't know much about these cars so any advice will be greatly appreciated.
Old 04-28-2024, 01:02 PM
Jett914
Jett914's Avatar
Default , and
The 75 1.8 and 2.0 fuel pumps are the same. http://www.autoatlanta.com/porsche-p...section=201-15, 1976 is the same.
Carrera51 (05-01-2024)
Old 05-01-2024, 03:36 PM
Dr. 914
Premium Dealer
Dr. 914's Avatar
we have many in stock, mounted up front Also check the main power relay and make sure that when the key is turned on the injectors click once as well
Old 05-01-2024, 03:41 PM
Carrera51
Carrera51's Avatar
Thank you for replying! I appreciate it. Now to get to work. I forwarded your info to my friend.
Quick Reply: Correct fuel pump for a 1976 914 2.0
