After a 25 Year Break, 914 Ownership Again
#751
Obviously the seat inserts are totalyl NON original but I"m sure you already know that! I used to take the bottom cushion out when I autocrossed the '71 back in the day to get a more "bucket" seat fitting... I put stock looking alcantara inserts on the '73 as they are much cooler in the AZ heat compared to the stock vinyl. Luckily the pepita inserts in the '71 already feel cooler and look great.
#752
Another task I forgot before the paint shop: drilling holes for the engine compartment floor deflectors. I had the kit from 914 Rubber, with 5 mm bolts that screw into the molded plastic.
So, on to marking holes, drilling holes, and painting holes.
Test fit.
Test fit.
#753
I picked up some of my engine parts at Competition Engineering in Phoenix.
Lots of air-cooled clutter.
Heads cleaned and checked, and complete valve job.
Crank measured and journals polished.
#754
Official Wednesday AM Red Bull F1 test driver
Yep, that place looks very familiar! Same old microbus out front!
Should have stopped by on your way out of town- I'd given you a couple Red Bulls. Not that far off the Bee Line Highway which I assume you took to get to Payson...
#755
Thanks for the offer. We made a fast trip from an to Tucson on I-10.
#756
More progress in Tucson today. I dropped the fuel tank with one of the few shops that still does the "boil out" treatment.
I then visited with a local custom auto upholstery shop. Restoration purists can cover their eyes, but I am looking for something a bit different from stock. Based on the discussion and looking at swatches I might go with a stock texture vinyl for the console, center armrest-storage cubby, seat bolsters, and door card tops. Seat cushions, lower door cards, and the dash strip will be a light gray perforated artificial suede.
#757
The door cards are in generally good shape, but have a bit of warping, especially on the driver side. I stripped the original vinyl so I could try to straighten the worst spots.
I sprayed both sides with water, placed them on flat concrete, and weighted them down with lumber scraps. We will see tomorrow if I made things better or worse.
#758
Back at the upholstery shop. I think I will change the gray perforated suede for perforated vinyl. This will go on the seating surfaces, lower part of the door panels, and across the dash center.
#759
I picked up the rest of my engine parts at Competition Engineering in Phoenix. Dan checked the case and tapped all the pug holes.
They also balanced the rods.
And sourced the new bearings and gasket set.
TYPE911 (12-11-2020)
