Door fit
Door fit
I'm having a hard time getting the doors on my 66 912 to close flush. I've adjusted the strikers a bunch of times. The doors will latch cleanly on the first "click" position. Then with effort I can close them to the second position. But with a little pressure, the door will pull open to the first click position. I can't figure this out at all. Everything appears lined up okay, but something isn't right. Any ideas?
Thanks - Bill
Thanks - Bill
Hello
The problem is inside the door lock system.
Just remove the door panel and clean the backside and then use some HT spray between the backplate and the large sliding plate.
Also retorque the M5 bolts on the lock
Grüsse
Grüsse
Superdave312 (05-29-2020)
