'67 912 no start...
'67 912 no start...
Good morning, I wonder if someone has any insight… 1967 912 been dormant at all winter, ran perfect when stored. Tried to start it now, I get no ignition lights or fuel pump (have an electric pump installed) but no crank… All lights, accessory's work, battery is new and fully charged is there a main fuse somewhere or is this a ground strap issue? Thanks in advance for any advice
Do you mean you are getting normal function but no crank? And by "crank" do you mean the starter will not spin the engine?
How about this... Tell me - if you turn the key - does anything happen. And if something is happening, tell me what. (what light comes on, hear a click or thud).
I am pretty old school. Turn the key on, spray a bit of fuel in the carbs, & then try to push start the car. If it fires ~ then it is probable that you have a starter problem.
