Turbocharger replacement
So my turbo needs to be either rebuilt or replaced on my 78 930. My shop will research and recommend but was wondering if you all had any ideas?
Specifics needed...
Can't offer legit ideas without more info. Such as....
Budget
Performance Expectations
Current build (100% stock or....?)
Cheers,
Ross
Budget
Cheers,
Ross
Sounds like a good opportunity to upgrade the turbo, even if it si a stock car you should go with a K27-7200 or better. It will help build boost quicker and will make the car a lot more fun to drive. If it is modified I would probably upgrade to a k27/29 depending on power needs.
Good grief. See what happens when you're old. I'm losing my mind, thought I had included that originally when I posted this thread! Anyway, it's got 964 cams, p&p heads, 3.4L, and a better exhaust, inter cooler etc.
