Follow up to my new 79 930
I had the top end rebuilt as well as the tranny synchros....
I still have a slight bit of smoke on startup.....only about 200 miles on the car since then.....probably not seated yet but wanted opinions. Also the tranny has been freshly redone and is stiff shifting....I assume this will lessen over the next 500 miles or so? Thanks Chas |
Originally Posted by 964TURBOCHAS
(Post 12756871)
Is this your first air-cooled, horizontally-opposed, motor? They all do that, to some degree...the longer they sit, the longer the puff. What gear oil did your rebuilder use? As far as I'm concerned, Swepco 201 is the gold standard for the 4-sp 930 box. YMMV... |
Originally Posted by mel_t_vin
(Post 12757810)
How much smoke...a puff that goes away in a couple seconds?
Is this your first air-cooled, horizontally-opposed, motor? They all do that, to some degree...the longer they sit, the longer the puff. What gear oil did your rebuilder use? As far as I'm concerned, Swepco 201 is the gold standard for the 4-sp 930 box. YMMV... Ill reach out to the rebuilder and heck on the gear oil used.. Thanks Chas |
Could be a little bit of a oil on the cold side of the turbo
Originally Posted by MUSSBERGER
(Post 12759146)
Could be a little bit of a oil on the cold side of the turbo.
Chas, do you suspect the 3LDZ is the original, 48k, turbo? This would be easy to check. Remove the intercooler and separate the up-pipe from the compressor housing. If the turbo seals are loosing their effectiveness, you may find some oil pooled at the compressor outlet...which, when the engine is started, gets sucked into the intake and burned. |
(Post 12759638)
True.
Chas, do you suspect the 3LDZ is the original, 48k, turbo? This would be easy to check. Remove the intercooler and separate the up-pipe from the compressor housing. If the turbo seals are loosing their effectiveness, you may find some oil pooled at the compressor outlet...which, when the engine is started, gets sucked into the intake and burned. Ill check the seals next week....thank you |
(Post 12757810)
How's your turbo oil tank?
Originally Posted by WPOZZZ
(Post 12765477)
(Post 12763316)
Mel Swepco 201 was what was used.
+1 for Allen's comment on Swepco 201. A good condition/properly setup transaxle with Swepco 201 should be very smooth. |
Originally Posted by Porsche 930
(Post 12766001)
Chas,
+1 for Allen's comment on Swepco 201. A good condition/properly setup transaxle with Swepco 201 should be very smooth. ill keep you posted |
(Post 12763316)
As Bud said, a 930 box with Swepco should be [buttery] smooth. Keep us in the loop. |
ok drove the car today.....shifts are really smooth and the smoke has gone away.
Pretty sure the smoke was because its been sitting for 2 weeks.....car runs great!!!!!! |
(Post 12770499)
Shifts are really smooth and the smoke has gone away. Pretty sure the smoke was because its been sitting for 2 weeks.
Happy motoring. |
