Moving with a 930 into California..
If you retard your ignition timing, via an aftermarket engine management solution, or otherwise, you will almost surely pass. This is one of the oldest tricks in the book.
Just get a Electromotive Tec-II and program in a "pass smog test" setting.
So far it looks like SF is the most expensive place on earth... I'm having the rebuild done in Toronto. I have a mechanic with whom I'm very happy, and the labour is all in Canadian dollars! It seems like you can have almost any amount of horsepower you like. It's just a financial decision...
Maybe compared to Toronto, but last summer, I thought the cost of living in TO was pretty high. The real cost shock that you will face is home prices. The SF/Bay area is about as high as you can get in North America. After finding a home, all else should be pretty much as in Toronto. Don't forget, we have no darn GST! Best of luck w/ the 930 re-build. Total or top/bottom?
