Wheel Offset Question
Looking at a set of kinesis wheels and the seller does not know the offset
Anyone know the offset for a 930turbo?
7x9 front
7x11 rear
7x9 front
7x11 rear
Trucker
I am just going through this exercise, and by this weekend I can actually make a real measurement for you...But my best estimate based on my "studies" and input from the folks here on RL: (Maybe someone smarter can confirm):
17X9 front: 30mm offset
17X11 rear: 44mm offset
**And don't forget that you should have a 28mm spacer in the rear and none in the front...of course, I have no clue what year your 930 is...this was the case on the 80's 930....
There is a range of acceptable offsets depending on a few variables (with or without stock spacers for example).
Generally up front a 9x17 wheel around +30 offset is a safe bet.
In the back with a 11x17 wheel around +6 (without rear spacer) through +40 (with spacer) works well. I much prefer the setups without rear spacers.
The pics below are Dave 86 930 FL's car with the following specs:
http://forums.pelicanparts.com/7158875-post5.html
Forgelines 17 x 9"/11"
Front Offset +31 (used stock spacers)
Rear Offset +06 (no rear spacers)
That's perfect fitment if you ask me!
