Torsion bars regulation
I changed rare torsion bars on 86' 930 and don't know on which height to regulate them. And from what place to determine this height.
Please help.
Sergey
Please help.
Sergey
uninformed gas bag
(contemplating on whether gas bag is one or two words)
http://www.rennlight.com/cgi-bin/spring.cgi
Not sure what you mean but you measure desired height at the top of the wheel arch and you are in for a bit of trial and error.
uninformed gas bag
The floor. If you just had the car on jacks you need to let it settle down. I have to drive mine to get it there. Have someone in the drivers seat and a full tank of fuel would help.
This link doesn't work anymore?
Originally Posted by voodoo51:10761144
Thanks for your help.
Could you please answer from which point to determine height (26 mm - rear, 20 mm - front)?
I believe the 26 mm / 20 mm dimensions you give would be the diameter of the bars themselves, not your height measurements.
After changing rear torsion bars left side of the car always getting lower than right side (about 2-3 cm).
Than I bought 2 "Axle support rear with possibility of adjustment" (part #: 91133300905) but anyway left side is lower (1.5 cm).
What could it be?
What could it be?
