rear fuel pump
rear fuel pump
Hi
I would like to know how the inlet hose for the rear fuel pump on a 930 is attached to the pump. The hose on my pump is a 1/2" hose with a hose clamp. I thought there is too much presure in the line for this kind of clamp. I can understand a barbed fitting on the front pump inlet but not the rear.
Thanks for your time
Dean
Dean
My rear pump has a fitting that screws into the pump with a bevel and the line screws into that by way of a barrell nut. Same exact way the fuel filter and accumulator lines are. It looks just like a fitting from Earls, or AN that you make up yourself.
