GHL heat exchanger up pipes
Re: 930 GHL headers with heat exchangers. If you bought a set of 930 GHL headers with heat exchangers....and do not use the heat part...like in a race car...I need the two approximately 2 inch by 12 inch ....approximately 90 degree angle tubing pipes....... that attach to heat the exchanger...with a clamp...and then head up toward the heater flapper boxes. A piece of flexable heater hose connects these pipes to the flapper boxes. I bought a set of GHL headers....with cracked welds...which all GHL's that I've ever seen quickly develope.... correctly welded and reinforced them...but do not have these two pipes. I know I can have a local make them out of steel etc. etc. but I'd rather first try to find two originals. Thanks....Bruce Eyring 770.315.5977 budgetmh@gmail.com
