Who's 734whp '89 930 Is This? Video.
DAMN, anyone know this car and the list of modifications?!
http://www.youtube.com/watch?v=eB-Tuw_3dtA&NR=1
Yasin
Yasin
Not Forgotten
That's Dknebes car, i believe it's now over 800hp
He posted his build on the 60-130mph thread on the 993tt board, this was the list in 2005, no doubt it's changed a bit now, he was doing the 60-130mph runs in around 5 seconds then, who knows what it's like with the 840 odd BHP it now has, awesome engine though. Here's the list
Complete Engine Rebuild (Essa Tech)
Heads ported & flowed (Dave Jarvis)
Engine Management Tec3-r Full Sequential
Twin Plug Heads
Custom Garretson Turbo Ceramic Ball bearing
3.2 Carrera Manifold
Custom Equal length Headers (Essa Tech)
95lb Injectors
Pauter Rods
Racing Valve Springs
O-ring Heads
Andial 3.4 Cylinders & Pistons 7.5/1
Custom Intake
Greddy b boost controller
Tial 46mm Wastegate
Aeromotive Eliminator Fuel Pump
Custom Intercooler Larger throttle body (Essa Tech)
High Strength ARP Cylinder Studs
High Strength ARP Rod Bolts
Custom grind Cams
Tilton 7.25" carbon, carbon 3 plate racing clutch 1400 lb-ft
Quaife Differential
Coilovers front and rear
Wide band A/f gauge
993 Big Reds
Borla XR-1
Twin Plug Heads
95lb Injectors
Pauter Rods
O-ring Heads
Custom Intake
Tial 46mm Wastegate
Custom grind Cams
Quaife Differential
Wide band A/f gauge
993 Big Reds
Borla XR-1
Yes it is David's. A beautiful 930 with an amazing engine.
Here is the link to his 60-130mph run. It was 6.52 seconds in fact, I am not sure about the dyno numbers of ESSA though as my car did the run a bit faster and I recon it had true 620-650 fwhp max at the time of the run with very close weight.
https://rennlist.com/forums/showpost...&postcount=806
Thank You
Since were on the subject. I've seen this car on You Tube, in pics, etc... Anyone know who this car belongs to?
http://www.youtube.com/watch?v=_vhKH...eature=related
Thanks for the replies guys.
Very very impressive and ultra cool.
Yasin
Yasin
One of my employees was showing me pics of this car. He is a Mitsubishi guy and loves cars. IIRC the car resides somewhere in the tri-state NYC area. I will see what I can find out.
Formula One Spin Doctor
